Delta C200 Series Drive
1,035
Jun 04, 2024 11:39 am
Master the Delta C200 drive with a comprehensive guide to its control parameters. Learn about basic operation, monitoring, protection, I/O control, and communication. Fine-tune motor performance and ensure safe operation.
Delta C200 drive parameters - This guide explores its control parameters, enabling you to optimize motor performance and safeguard operation. Discover essential parameters for start/stop, speed control, monitoring, protection, and communication.
Factory Reset | |||
00-02 | 9 | ||
Start/Stop | |||
00-21 | 0 | Digital Keypad | |
1 | External Terminal | ||
2 | RS485 Comm | ||
Speed Reference | |||
00-20 | 0 | Digital Keypad | |
1 | 485 Comm | ||
2 | Analog Input | ||
3 | External UP/Down | ||
7 | Keypad Potentiometer | ||
Stop Mode | |||
00-22 | 0 | Rmp to stop | |
1 | Cost to stop | ||
ACC/Dec Time | |||
01--12 | …...s | Acc time | |
01--13 | …...s | Dec Time | |
2-wire/3-wire | |||
02--00 | 0 | 2-wire mode | |
2 | 3-wire | ||
02-01 to 02-08 | |||
1 | 1: Multi-step speed command 1 | ||
2 | 2: Multi-step speed command 2 | ||
3 | 3: Multi-step speed command 3 | ||
6 | 6: JOG command | ||
19 | 19: Digital up command | ||
20 | 20: Digital down command | ||
Jog Freq | |||
01-22 - | ….Hz | JOG Frequency | |
Relay Output | |||
RO1 | 02--13 | 9 | 9: Drive is ready |
1 | 1: Operation Indication | ||
11 | 11: Malfunction indication | ||
RO2 | 02--14 | 9 | 9: Drive is ready |
Motor Data | |||
05--01 | …...A | Motor Current | |
05--02 | …...KW | Motor Power | |
05--03 | …...rpm | Motor Speed | |
Communication | |||
09-00 | ….. | Station ID/Comm Address | |
09--01 | …... | Baud Rate(4.8~115.2Kbps) | |
Communication | 09--04 | ….. | 0: 7N1 (ASCII) |
1: 7N2 (ASCII) | |||
2: 7E1 (ASCII) | |||
3: 7O1 (ASCII) | |||
4: 7E2 (ASCII) | |||
5: 7O2 (ASCII) | |||
6: 8N1 (ASCII) | |||
7: 8N2 (ASCII) | |||
8: 8E1 (ASCII) | |||
9: 8O1 (ASCII) | |||
10: 8E2 (ASCII) | |||
11: 8O2 (ASCII) | |||
12: 8N1 (RTU) | |||
13: 8N2 (RTU) | |||
14: 8E1 (RTU) | |||
15: 8O1 (RTU) | |||
16: 8E2 (RTU) | |||
17: 8O2 (RTU | |||
Comm Fault | 09--02 | 0 | Warn and continue operation |
1 | Warn and ramp to stop | ||
2 | Warn and coast to stop | ||
3 | No warning and continue operation | ||
Fan Control | |||
07--19 | 0 | Fan always ON | |
1 | 1 minute after the AC motor drive stops | ||
2 | When the AC motor drive runs, the fan is ON |
