Delta C2000 Plus/C2000 Series Drive
2
595
May 14, 2022 12:12 pm
How can resolve problem AboF fault in delta C2000 series drive ?
PG ABZ line off (AboF)
The drive detects the ABZ line off when using ABZ and UVW signal encoder (only supports PG02U line off function).
The ABZ signal is cut off - Check if the signal cable between encoder and PG card is correct or cut off.
