ACE fault in delta C2000 series drive
How can resolve problem ACE fault in delta C2000 series drive ?
ACI loss (ACE)
Analog input loss (including all the 4–20 mA analog signal)
Action conidition - When the analog input is < 4 mA (only detects 4–20 mA analog input).
When Pr.03-19 = 1 or 2, ACE is a “Warning”. When analog input signal is > 4 mA, the warning is automatically cleared.
When Pr.03-19 = 3, ACE is a “Fault”. You must reset manually.
ACI cable is loose or cut off - Tighten the terminal. Replace the cable with a new one.
Fault treatment parameter
Pr.03-19
0: Disable
1: Continue operation at the last frequency (warning, ANL is displayed on the keypad)
2: Decelerate to stop (warning, ANL is displayed on the keypad)
3: Stop immediately and display ACE
