Brk fault in delta C2000 series drive
How can resolve problem Brk fault in delta C2000 series drive ?
External brake error (Brk)
External mechanical brake error The MO terminal is active when MOx = 12, 42, 47 or 63, but the MIx = 55 does not receive signal for mechanical brake action during the set time of Pr.02-56.
MIx = 55 did not receive signal for the mechanical brake action during the set
time of Pr.02-56
Mechanical brake error -
Verify if the mechanical brake can work correctly.
Replace mechanical brake.
Incorrect parameter setting - If there is no brake-confirming signal to use, set Pr.02-56=0.
The time of Pr.02-56 is set too short - Increase the time setting of Pr.02-56.
