delta c2000 manual fault codes
delta c2000 manual fault codes - fault comes when hardware issue in power card, control control card, improper control & power wiring or incorrect parameter issue in drive.
Cause : Due to improper function in drive like faulty input or output, faulty control card or power card and incorrect parameter drive generate fault. Follow these step to correct fault :
1. Check input wiring and output wiring.
2. Check parameters - like motor data and start stop data.
3. Hardware issue in drive like faulty power card and control card drive generate fault.
4. Check earthing - using multi-meter check drive earthing.
Click here for all fault, alarm & warning in delta C2000 drive.
