EoL1 fault in delta C2000 series drive
How can resolve problem EoL1 fault in delta C2000 series drive ?
Electronic thermal relay 1 protection (EoL1)
Electronic thermal relay 1 protection. The drive coasts to stop once it activates.
Start counting when output current > 105% of motor 1 rated current
Action time - Pr.06-14 (if the output current is larger than 105% of motor 1 rated current again within 60 sec., the counting time reduces and is less than Pr.06-14)
The load is too large - Reduce the load.
Decrease low-speed operation time.
Replace the drive with a dedicated to VFD model.
Increase the motor capacity
Check wiring.
