oH1 IGBT overheating warning in delta C2000 series drive
How can resolve oH1 IGBT overheating warning in delta C2000 series drive ?
IGBT overheating warning (oH1)
The AC motor drive detects over-heating of IGBT, and over the protection level of oH1 warning. (When Pr.06-15 is higher than the IGBT overheating level, the drive shows oH1 error without displaying oH1 warning.)
Action time - “oH1” warning occurs when IGBT temperature is higher than Pr.06-15 setting value.
1. Check the ambient temperature.
2. Regularly inspect the ventilation hole of the control cabinet.
3. Change the installed place if there are heating objects, such as braking
resistors, in the surroundings.
4. Install/ add cooling fan or air conditioner to lower the temperature inside the
cabinet.
Check if the drive matches the corresponded loading -
1. Decrease loading.
2. Decrease the carrier.
3. Replace with a drive with larger capacity.
