oSL warning in delta C2000 series drive
How can resolve oSL warning in delta C2000 series drive ?
Over slip warning (oSL)
Over slip warning. By using the maximum slip (Pr.10-29) as the base, when the drive outputs at constant speed, and the F>H or F<H exceeds Pr.07-29 level and Pr.07-30 setting time, 100% Pr.07-29 = Pr.10-29.
Check if the motor parameter is correct - Check the motor parameter.
Warning setting parameter
Pr.07-31 = 0 Warning
0: Warn and keep operation
1: Fault and ramp to stop
2: Fault and coast to stop
3: No warning
When Pr.07-31 = 0 and when the drive outputs at constant speed, and F > H or F < H no longer exceeds the Pr.07-29 level, the oSL warning automatically clears
