SfLK fault in delta C2000 series drive
How can resolve problem SfLK fault in delta C2000 series drive ?
PMLess shaft lock (SfLK)
The drive has RUN command with output frequency, but the permanent magnetic motor does not turn.
Improper setting of the speed observer bandwidth - Increase the setting value.
Motor shaft lock - Remove causes of the motor shaft lock.
