Delta C2000 Plus/C2000 Series Drive
2
624
May 14, 2022 12:13 pm
How can resolve problem UvoF fault in delta C2000 series drive ?
May 14, 2022 12:14 pm
PG UVW line off (UvoF)
The drive detects the UVW line off when using ABZ and UVW signal encoder (only supports PG02U line off function).
The UVW signal is cut off - Check if the signal cable between encoder and PG card is correct or cut off.
