Delta REG2000 drive factory reset parameter
Learn how to perform a factory reset on the Delta REG2000 drive. Discover the specific parameter to restore default settings, ensuring optimal performance and resolving configuration issues.
If you want to factory reset Delta REG2000 drive parameter then use the following step :
2. Then goto the parameter group 01.
3. After enter into group 01 then goto the parameter 01.00 and select 10.
