al009 delta
Cause : Excessive Deviation of Position Command comes when the actual position of the motor shaft deviates too much from the commanded position.
al009 delta indicates a "Position Error out of range" issue. This means the deviation of position command exceeds the allowable setting value.
  • Check the setting value of parameter P2-35.
  • Check if the setting value is appropriate.
  • Check the torque limit value.
  • Check the external load.
