Delta Drives
411
Jun 22, 2024 12:48 pm
Cause : CANopen bus off error comes when the master receives wrong communication package, the CbFE fault occurs or too much interference on BUS. The master receives wrong package when the CAN_H and CAN_L communication cables are short, CbFE fault occurs.
- Make sure the CANopen card is installed.
- Reset CANopen speed.
- Verify the wiring and grounding of the communication circuit.
- Make sure the communication circuit is wired in series.
- Use CANopen cable or add terminating resistance.
- Check or replace the communication cable.
