Delta Drives
400
Jun 22, 2024 12:59 pm
Cause :Â Modbus transmission time-out comes when incorrect communication command from upper unit or malfunction caused by interference.
The CE10 fault in delta drive indicates an Modbus transmission time-out. This means the communication time exceeds the detection time for communication time-out.
- Check if the communication command is correct.
- Check the cable and replace it if necessary.
