Delta Drives
445
Jun 22, 2024 1:01 pm
Cause :Â Illegal data address comes when incorrect communication command from upper unit or malfunction caused by interference. The drive resets automatically when receiving the correct function code.
The CE2 fault in delta drive indicates an Illegal data address error. This means the drive received incorrect communication command from the upper unit.
- Check if the communication command is correct.
- Check the cable and replace it if necessary.
