CE4 warning in delt...
CE4 warning in delta drive
Cause : Communication error 4 comes when incorrect communication command from upper unit or malfunction caused by interference. The drive resets automatically when receiving the correct function code.
The CE4 warning in delta drive indicates an "Illegal command" error. This means the drive received a command that it doesn't understand or can't execute.
  1. Check if the communication command is correct.
  2. Check the cable and replace it if necessary.
