Delta Drives
495
Jun 24, 2024 10:43 am
Cause : Deviation Warning comes when the motor speed has exceeded the programmed speed limit by a certain percentage. This fault comes when improper parameter setting for the slip error or mechanical brake is not released.
- Reset ASR parameters. Set proper accel./ decel. time.
- Remove the causes of motor locked.
- Check the action timing of the system.
