delta drive alarm l...
delta drive alarm list
delta drive alarm list: Experiencing a Delta Drive alarm? Learn what your specific alarm code means and get actionable steps to fix the issue and minimize downtime.
Below list show delta drive fault code:
Alarm Name
Fault Descriptions
Corrective Actions
 oca
Over-current during acceleration  (Output current exceeds triple rated current during acceleration.)
1.      Short-circuit at motor output: Check for possible poor insulation at the output lines.
2.      Acceleration Time too short: Increase the Acceleration Time.
3.      AC motor drive output power is too small: Replace the AC motor drive with the next higher power model.
 ocd
Over-current during deceleration (Output current exceeds triple rated current during deceleration.)
1.      Short-circuit at motor output: Check for possible poor insulation at the output line.
2.      Deceleration Time too short: Increase the Deceleration Time.
 ocn
Over-current during steady state operation
(Output current exceeds triple rated current during constant speed.)
2.      Sudden increase in motor loading: Check for possible motor stall.
 oc5
Hardware failure in current detection
Return to the factory
Gff
Ground fault
When (one of) the output terminal(s) is grounded, short circuit current is more than 50% of AC motor drive rated current, the AC motor drive power module may be damaged. NOTE: The short circuit protection is provided for AC motor drive protection, not for protection of the user.
1.      Check the wiring connections between the AC motor drive and motor for possible short circuits, also to ground.
2.      Check whether the IGBT power module is damaged.
3.      Check for possible poor insulation at the output line.
occ
Short-circuit is detected between upper bridge and lower bridge of the IGBT module
oca
DC BUS over-voltage during acceleration (230V: DC 450V;
460V: DC 900V)
1.       Check if the input voltage falls within the rated AC motor drive input voltage range.
2.       Check for possible voltage transients.
3.       If DC BUS over-voltage due to regenerative voltage, please increase the Deceleration Time or add an optional brake resistor.
oud
DC BUS over-voltage during deceleration (230V: DC 450V;
460V: DC 900V)
oun
DC BUS over-voltage in constant speed
(230V: DC 450V; 460V: DC 900V)
ou5
Hardware failure in voltage detection
Check if input voltage is within specification range and monitor if there is surge voltage.
Lud
DC BUS voltage is less than Pr.06-00
during acceleration
1.       Check if the input voltage is normal
2.       Check for possible sudden load
Lun
during deceleration
DC BUS voltage is less than Pr.06-00 in
constant speed
PHL
Phase Loss
Check Power Source Input if all 3 input phases are connected without loose contacts.
For models 40hp and above, please check if the fuse for the AC input circuit is blown.
Oh1
IGBT overheating IGBT temperature exceeds protection level
1 to15HP: 90 oC
20 to 100HP: 100 oC
1.       Ensure that the ambient temperature falls within the specified temperature range.
2.       Make sure that the ventilation holes are not obstructed.
3.       Remove any foreign objects from the heatsinks and check for possible dirty heat sink fins.
4.       Check the fan and clean it.
5.       Provide enough spacing for adequate ventilation.
oh2
Heatsink overheating Heat sink
temperature exceeds 90oC
oh3
Motor overheating The AC motor drive detects that the internal temperature exceeds Pr.06-30 (PTC level)
1.       Make sure that the motor is not obstructed.
2.       Ensure that the ambient temperature falls within the specified temperature range.
3.       Take the next higher power AC motor drive model.
OH1 hardware failure
OH2 hardware failure
Fan
Fan failure
1.       Make sure that the fan is not obstructed.
2.       Return to the factory
ol
Overload
The AC motor drive detects excessive drive output current. NOTE: The AC motor drive can withstand up to 150% of the rated current for a maximum of 60
seconds.
1.     Check whether the motor is overloaded.
2.      Take the next higher power AC motor drive model.
EoL1
Motor 1 overload
1.       Check whether the motor 1 is overloaded.
2.       Check whether the rated current of motor 1 (Pr.05-01) is suitable
EoL2
Motor 2 overload
1.       Check whether the motor 2 is overloaded.
2.       Check whether the rated current of motor 2 (Pr.05-13) is suitable
FuSE
Broken fuse
The fuse at DC side
is broken for 30hp and below
1.        Check whether the fuse of the transistor module is functioning well
2.        Check whether the loading side is short- circuit
ot1
Electronic Thermal Relay 1 Protection
2.       Check whether motor rated current setting (Pr.05-01) is suitable
3.       Check electronic thermal relay function
4.       Take the next higher power AC motor drive model.
ot2
Electronic Thermal Relay 2 Protection
cF1
Internal EEPROM can not be programmed.
1.       Press “RESET” key to the factory setting
2.       Return to the factory.
cF2
Internal EEPROM can not be read.
cd0
Re-power on to try it. If fault code is still displayed on the keypad please return to the factory
cd1
U-phase error
cd2
V-phase error
cd3
W-phase error
Hd0
CC (current clamp)
Hd1
OC hardware error
Hd2
OV hardware error
Hd3
GFF hardware error
AuE
Auto tuning error
1.       Check cabling between drive and motor
2.       Retry again
AFE
PID loss (ACI)
1.        Check the wiring of the PID feedback
2.        Check the PID parameters settings
PGF1
PG feedback error
Check if Pr.10-01 is set to 0 when it is PG feedback control
PGF2
PG feedback loss
Check the wiring of the PG feedback
PGF3
PG feedback stall
1.        Check the wiring of the PG feedback
2.        Check if the setting of PI gain and deceleration is suitable
3.        Return to the factory
PGF4
PG slip error
PGr1
Pulse input error
1.        Check the pulse wiring
PGr2
Pulse input loss
ACE
ACI loss
1.        Check the ACI wiring
2.        Check if the ACI signal is less than 4mA
EF
External Fault
1.       Input EF (N.O.) on external terminal is closed to GND. Output U, V, W will be turned off.
2.       Give RESET command after fault has been cleared.
EF1
Emergency stop
1.       When the multi-function input terminals MI1 to MI6 are set to emergency stop, the AC motor drive stops output U, V, W and the motor coasts to stop.
2.       Press RESET after fault has been cleared.
bb
External Base Block
1.      When the external input terminal (B.B) is active, the AC motor drive output will be turned off.
2.      Deactivate the external input terminal (B.B) to operate the AC motor drive again.
Pcode
Password is locked.
Keypad will be locked. Turn the power ON after power OFF to re-enter the correct password. See Pr.00-07 and 00-08.
cE1
Illegal function code
Check if the function code is correct (function code must be 03, 06, 10, 63)
cE2
Illegal data address
Check if the communication address is correct
cE3
Illegal data value
Check if the data value exceeds max./min. value
cE4
Slave device failure
Check the connection of the Slave device
cE10
Communication time-out
Check if the wiring for the communication is correct
cP10
Keypad (KPV-CE01) communication time-out
1.         Check if the wiring for the communication is correct
2.         Check if there is any wrong with the keypad
bf
Braking resistor fault
If the fault code is still displayed on the keypad
after pressing “RESET” key, please return to the factory.
ydc
Y-connection/ Δ - connection switch error
1.        Check the wiring of the Y-connection/ Δ- connection
2.        Check the parameters settings
