Delta Drives
270
May 15, 2025 12:54 pm
delta drive fault code: Experiencing a Delta Drive error? Learn what your specific fault code means and get actionable steps to fix the issue and minimize downtime.
Below list show delta drive fault code:
- CE2 warning in delta drive indicates Communication error 2. This means an incorrect communication command from upper unit or malfunction caused by interference.
- CE1 warning in delta drive indicates Communication error 1. This means incorrect communication command from upper unit or malfunction caused by interference.
- PID warning in delta drive indicates PID feedback error. This means an issue with the signal coming from the sensor used for PID control.
- oH1 warning in delta drive indicates IGBT over-heating warning. This means the drive's internal temperature has exceeded the safe operating limit.
- SE2 warning in delta drive indicates Save error 2. This means writing the parameters incorrectly at the time you copy parameters to the drive.
- SE1 warning in delta drive indicates Save error 1. This means the keypad failed to transmit the COPY command to the drive within the expected timeframe.
- CE10 warning in delta drive indicates Communication error 10. This means incorrect communication command from upper unit or malfunction caused by interference.
- CE4 warning in delta drive indicates Communication error 4. This means incorrect communication command from upper unit or malfunction caused by interference.
- CE3 warning in delta drive indicates Communication error 3. This means incorrect communication command from upper unit or malfunction caused by interference.
- ot4 warning in delta drive indicates Over-torque 4 warning. This means the motor connected to the drive has exceeded the set torque limit for a certain period.
- ot3 warning in delta drive indicates Over-torque 3 warning. This means the motor connected to the drive has exceeded the set torque limit for a certain period.
- SE3 warning in delta drive indicates Copy model error 3. This means different drive identity codes are found during copying parameters.
- tUn warning in delta drive indicates Auto tuning. This means parameter auto-tuning is processing or when running auto-tuning, the keypad displays “tUn”.
- oSL warning in delta drive indicates Over slip warning. This means the motor speed has deviated from the programmed speed limit by a certain amount for a specific duration.
- ot2 warning in delta drive indicates Over-torque. This means the motor connected to the drive has exceeded the set torque limit for a certain period.
- ot1 warning in delta drive indicates Over-torque 1. This means the motor connected to the drive has exceeded the set torque limit for a certain period.
- PHL warning in delta drive indicates Phase loss. This means the drive is not detecting all three phases of the incoming AC power supply.
- dAvE warning in delta drive indicates Deviation Warning. This means the motor speed has exceeded the programmed speed limit by a certain percentage.
- AnL warning in delta drive indicates ACI analog signal loss. This means the analog input is lower than 4 mA (only detects analog input 4–20 mA).
- ECto warning delta drive indicates Communication time-out. This means communication card is not connected with the upper unit or communication error of the upper unit.
- ECCS warning delta drive indicates Checksum error. This means checksum error for the communication card and the drive due to noise interference.
- ocA fault delta drive indicates Over-current during acceleration. This means the motor's current has exceeded a specific limit.
- ocd fault delta drive indicates Over-current during deceleration. This means the current flowing from the motor back to the drive during deceleration (slowing down) has exceeded the set limit.
- ocn fault delta drive indicates Over-current during steady operation. This means the current flowing from the drive to the motor has exceeded the set limit while the motor is running at a constant speed.
- GFF fault delta drive indicates Ground fault. This means the drive has detected a current leakage path between the AC power supply and the drive's grounding system.
- ocS fault delta drive indicates Over-current at stop. This means an over-current condition is detected even when the drive is not running.
- ovA fault delta drive indicates Over-voltage during acceleration. This means the output voltage from the drive to the motor has exceeded a specific limit during the acceleration phase.
- ovd fault delta drive indicates Over-voltage during deceleration. This means the voltage generated by the motor as it decelerates has exceeded the set limit on the drive.
- ovn fault delta drive indicates Over-voltage during constant speed. This means the DC bus voltage within the drive has exceeded a set limit while the motor is running at a constant speed.
- ovS fault delta drive indicates Over-voltage at stop. This means the drive's DC bus voltage exceeds the allowable limit when the motor is not running.
- LUA fault delta drive indicates Low-voltage during acceleration. This means the DC bus voltage within the drive has fallen below a set limit while the motor is accelerating.
- LUd fault delta drive indicates Low-voltage during deceleration. This means the DC bus voltage within the drive has fallen below a set limit while the motor is either running at a constant speed or decelerating.
- Lvn fault delta drive indicates Low-voltage at constant speed. This means the DC bus voltage within the drive has fallen below a set limit when the motor is running at constant speed.
- LvS fault delta drive indicates Low-voltage at stop. This means the DC bus voltage within the drive has fallen below a set limit while the motor is not running.
- tH1o fault delta drive indicates IGBT temperature detection failure. This means IGBT (Insulated-Gate Bipolar Transistor) is a critical component within the drive that controls the power flow to the motor.
- oL fault delta drive indicates Over load. This means the motor is drawing excessive current exceeding the drive's capacity for a sustained period.
- EoL1 fault delta drive indicates Electronics thermal relay 1 protection. This means the internal temperature of the drive's electronic components responsible for controlling motor current (likely involving IGBTs) has exceeded a safe operating limit.
- oH3 fault delta drive indicates Motor overheating. This means the drive has detected that the motor temperature has exceeded a safe operating limit.
- ot2 fault delta drive indicates Over torque 2. This means the motor connected to the drive has exceeded the set torque limit for a certain period.
- ot1 fault delta drive indicates Over torque 1. This means the motor connected to the drive has exceeded the set torque limit for a certain period.
- cF2 fault delta drive indicates EEPROM read error. This means internal EEPROM cannot be read due to hardware issue in drive power card or control card.
- cd1 fault delta drive indicates U-phase error. This means the drive is detecting an abnormality in the current flowing through the U phase of the motor.
- cd2 fault delta drive indicates V-phase error. This means the drive is detecting an abnormality in the current flowing through the V phase of the motor.
- cd3 fault delta drive indicates W-phase error. This means the drive is detecting an abnormality in the current flowing through the W phase of the motor.
- AUE fault delta drive indicates Auto-tuning error. This means the drive attempts to automatically calibrate itself to optimize performance for the connected motor, but the process fails to complete successfully.
- PGF2 fault delta drive indicates PG feedback loss. This means incorrect setting of encoder parameter or incorrect selection of the control mode.
- Pcod fault delta drive indicates Password is locked. This means you have entered the wrong password for the keypad three times consecutively.
- PGF3 fault delta drive indicates PG feedback stall. This means the motor frequency exceeds the encoder observer stall level and starts to count, the fault time is longer than the detection time of encoder observer stall, then PGF3 fault occurs.
- PGF4 fault delta drive indicates PG slip error. This means the drive is operating in PG mode (using an encoder for speed and position control) and detects a discrepancy between the actual motor speed and the speed estimated by the encoder observer.
