delta error codes
Delta drives are equipped with a fault diagnostic system that can detect and identify various types of faults. If a fault occurs, the drive display will show the corresponding fault code along with a description of the fault.
delta error codes - If a fault occurs, the drive display will show the corresponding fault code along with a description of the fault. Some common faults that can occur on an delta drive include:
  1. Internal hardware faults
  2. Overcurrent
  3. Motor overload
  4. DC bus voltage too high or too low
  5. Motor phase loss
  6. Drive overtemperature
  7. Motor stall detected
  8. Drive communication faults
  9. Drive configuration faults
  10. Power stage faults
If a fault occurs, the drive display will show the corresponding fault code along with a description of the fault. It is important to consult the user manual.
