The "OU" or Overvoltage Fault in a Delta VFD (Variable Frequency Drive) typically indicates that the DC bus voltage has exceeded the drive’s allowable limit.
Common Causes of OU Fault:
Regenerative Braking: When the motor decelerates too quickly, it acts like a generator and pushes voltage back into the drive
Deceleration Time Too Short: A short deceleration time setting causes the motor to regenerate too much energy too quickly.
Improper Braking Setup: No braking resistor or braking unit installed when needed. Braking resistor is too small or faulty.
Power Supply Issues: Input voltage spikes or surges. Bad power quality (e.g., voltage imbalance or harmonics).
Increase Deceleration Time: Adjust parameter For Deceleration Time.
Install or Check Braking Resistor: Ensure a braking resistor is installed and properly sized. Check connections and condition of the resistor.
Add a Braking Unit (If Needed): Required for larger drives or frequent/fast deceleration cycles.
Use a Line Reactor or Surge Protector: Helps mitigate power line surges and voltage spikes.
Check for Sudden Load Changes: Rapid load reduction can cause regenerative energy to surge back into the drive.
Monitor Input Voltage: Use a multimeter or data logger to detect input surges or imbalance.
