Delta Drives
155
Jun 24, 2024 9:06 am
Cause : oc hardware error comes when the current sensing hardware within the drive. This error typically arises due to problems with the current clamp sensor, incorrect wiring, hardware faults, or interference.
Hd1 fault delta drive indicate current clamp hardware error. This means hardware protection error when drive power is ON.
- Cycle the power.
- Check drive IGBT using multimeter.
