Delta Drives
531
Jun 24, 2024 9:17 am
Cause : Low-voltage during deceleration comes when the DC bus voltage within the drive has fallen below a set limit while the motor is either running at a constant speed or decelerating.
The Lvd fault in delta drive indicates a Low-voltage During Constant Speed Operation condition. This means the DC bus voltage within the drive has fallen below a set limit while the motor is running at a constant speed.
- Immediately act when the DC bus voltage is lower.
- Improve power supply condition.
- Adjust voltage to the power range of the drive.
- Check the power system.
- Increase the capacity of power equipment.
