Delta Drives
416
Jun 24, 2024 9:15 am
Cause : Low-voltage at stop comes when the DC bus voltage within the drive has fallen below a set limit while the motor is not running.
The LvS fault in delta drive indicates a Low-voltage at stop. This means the DC bus voltage is lower than Pr.06-00 setting value at stop.
- Improve power supply condition.
- Check if the power specification matches the drive.
- Adjust voltage to the power range of the drive.
- Cycle the power after checking the power.
