Delta Drives
566
Jun 24, 2024 10:40 am
Cause : IGBT over-heating warning comes when the drive's internal temperature has exceeded the safe operating limit. This warning occurs when IGBT temperature is higher than maximum setting value.
The oH1 warning in Delta drive indicates an Overheat (Heatsink) fault. This means the heatsink, which is responsible for dissipating heat from the drive, has reached an excessively high temperature.
- Check the ambient temperature.
- Regularly inspect the ventilation hole of the control cabinet.
- Change the installed place if there are heating objects, such as brake resistors, in the surroundings
- Decrease loading.
- Decrease the carrier wave.
- Replace with a drive with larger capacity.
- install/ add cooling fan or air conditioner to lower the temperature inside the cabinet
