oPL1 fault in delta...
oPL1 fault in delta drive
Cause : Output phase loss U phase comes when the drive isn't detecting the expected current on the U phase connected to the motor.
The oPL1 fault in Delta drive indicates an output phase loss on the U phase. This means is a problem with the U phase output of the drive.
  1. Check the cable condition.
  2. Make sure the capacity of the drive and motor match to each other.
  3. Check motor cable.
