oPL3 fault in delta...
oPL3 fault in delta drive
Cause : Output phase loss W phase comes when the drive isn't detecting the expected current on the W phase connected to the motor.
The oPL3 fault in delta drive indicates an output phase loss on the W phase. This means is a problem with the W phase output of the drive.
  1. Check the cable condition.
  2. Make sure the capacity of the drive and motor match to each other.
  3. Check motor cable.
