oSL fault in delta ...
oSL fault in delta drive
Cause : Over slip error comes when the motor speed has deviated from the programmed speed limit by a certain amount for a specific duration.
The oSL fault in Delta drive indicates a Over slip error. This means the motor speed has reached the programmed speed limit set in the drive.
  1. Check the motor parameter.
  2. Check the parameter settings for oSL protection.
