Delta Drives
495
Jun 24, 2024 10:41 am
Cause : PID feedback error comes when an issue with the signal coming from the sensor used for PID control. This signal is crucial for the drive to determine the actual process variable (e.g., temperature, pressure) and adjust the motor output accordingly.
- When the analog input is lower than 4 mA (only detects analog input 4–20 mA).
- The Warning automatically clears when the feedback signal is larger than 4 mA.
- Loose or broken PID feedback wiring then tighten the terminals again. Replace with a new cable.
- If feedback device malfunction then replace with a new feedback device.
