SE1 Save error 1 Warning in delta ME300 series Drive
How can resolve problem SE1 Save error 1 Warning in delta ME300 series Drive ?
Cause : SE1” warning occurs when the keypad does not transmit the COPY command
to the drive, and does not transmit any data to the drive again in 10 ms at the
time you copy the parameters to the drive
Communication connection error.
SE1: The causes of error are mostly communication problems between the
keypad and control board. Potential causes include communication signal
interference and the unacceptable communication command to the Slave.
It is not suggested to consider the communication quality at this time.
Check if the error occurs randomly, or only occurs when copying certain
parameters (the error displays on the upper right corner of the copy page)
