Learn how to perform a factory reset on the Delta MH300-L drive. Discover the specific parameter to restore default settings, ensuring optimal performance and resolving configuration issues.
If you want to factory reset Delta MH300-L drive parameter then use the following step :
2. Then press enter button and select 00 then press enter button.
3. After select 00 then press enter button again.
4. When display show 00.00 then press UP key two times then display show 00.02.
5. When display show 00.02 then press enter button and select 9 then press enter button.
