Delta MH300 Series Drive
2
485
Apr 26, 2022 12:18 pm
How can resolve problem OPHL warning in delta MH300 drive ?
Apr 26, 2022 12:20 pm
Output phase loss (OPHL)
Check if the wiring is incorrect - Check the cable. Replace the cable.
Check if the drive capacity is larger than the motor capacity - Choose the drive that matches the motor capacity.
Warning treatment parameter
Pr.06-45
0: Warn and continue operation
1: Fault and ramp to stop
2: Fault and coast to stop
3: No warning
This fault also comes when your motor rating is small as compare to drive and run drive without motor.
