uC warning in delta MH300 drive
How can resolve problem uC warning in delta MH300 drive ?
Topic Tags
Under current (uC)
Check the loading status.
Make sure the loading matches the motor capacity.
Warning treatment parameter
Pr.06-73
0: No function
1: Fault and coast to stop
2: Fault and ramp to stop by 2 nd deceleration time
3: Warn and continue operation
This warning also come when you connect small rating motor as compare to drive rating or you run drive without motor.
