bb fault delta ms300 drive
Cause : External base block comes when an external device or signal is intentionally stopping the motor by activating the base block function of the drive.
The "bb" error code on your Delta MS300 drive indicates an external base block. This means an external device or signal is actively preventing the drive from operating the motor.
  • Verify if the system is back to normal condition, and then press “RESET” key to go back to the default.
