CP22 fault delta ms300 drive
Cause : Internal communication error comes when the drive is having trouble communicating between its internal components.
The error code CP22 in MS300 drive indicates an internal communication error. This means the drive is experiencing issues with communication between its internal components.
Here's what you can do to troubleshoot the CP20 fault:
  1. Power Cycle: Often, a simple power cycle can resolve temporary glitches that might be causing the communication error. Turn off the power to the drive, wait for a few seconds, and then power it back on.
  2. Check Connections: Ensure all internal connections within the drive are secure.
  3. Review Settings: In rare cases, incorrect communication settings within the drive might be causing the issue. Double-check any communication parameters you might have configured.
