Delta MS300 Series Drive
2
5,441
Mar 17, 2023 6:42 am
delta ms300 error codes - fault comes when hardware issue in power card, control card, incorrect control and power wiring or parameter issue.
Mar 17, 2023 6:46 am
Cause : Drive generate fault due to hardware issue, incorrect parameter or wiring issue in drive. Following these step to correct fault :
1. Check motor parameter like voltage rating, current rating, motor power etc.
2. Check input/output wiring & control connection.
3. Check all communication parameter.
4. Check input supply and control supply in drive.
