ictn warning delta ms300 drive
Cause : InrCOM time-out comes when internal communication time-out due to malfunction caused by interference, different communication setting from the upper unit or disconnection or bad connection of the cable.
  1. The warning automatically clears when the communication is back to normal condition.
  2. Check if the setting for Pr.09-02 is the same as the setting for the upper unit.
  3. Check the cable and replace it if necessary.
