oH3 fault delta ms300 drive
Cause : Motor overheating comes when the drive has detected that the motor temperature has exceeded a safe operating limit.
The oH3 error code on your Delta MS300 drive indicates a Motor overheating condition. This means the drive has detected that the motor temperature has exceeded a safe operating limit.
  1. Reduce the load.
  2. Increase the motor capacity.
  3. Check the cooling system to make it work normally.
  4. Increase the setting values for Pr.01-12–01-19 (accel./decel. time).
  5. Reset to the correct motor rated current.
