Delta MS300 Series Drive
425
Jun 22, 2024 10:46 am
Cause : Over-torque 3 comes when the output current exceeds the over-torque detection level and exceeds over-torque detection time then this fault displays.
The fault ot3 in Delta MS300 drive indicates an over-torque 3 fault. This means the motor connected to the drive has exceeded its set torque limit for a certain period.
- Reduce the load.
- Replace the motor with a larger capacity model.
- Increase the setting for Pr.01-12–Pr.01-19 (accel./ decel. time).
- Adjust the torque compensation (refer to Pr.07-73 torque compensation gain).
