Delta MS300 Series Drive
2
1,068
Apr 26, 2022 7:07 am
How can resolve problem ovS fault in delta MS300 drive ?
Apr 26, 2022 7:08 am
Over-voltage at stop
Check if the input voltage is within the rated AC motor drive input voltage range,
and check for possible voltage spikes.
f the phase-in capacitor or active power supply unit activates in the same power
system, the input voltage may surge abnormally in a short time. In this case,
install an AC reactor.
Check the wiring of the brake resistor or braking unit.
Â
