Delta MS300 Series Drive
393
Jun 22, 2024 8:03 am
Cause : PG slip error comes when the drive is operating in PG mode (using an encoder for speed and position control) and detects a discrepancy between the actual motor speed and the speed estimated by the encoder observer.
The PGF4 error code on your Delta MS300 drive indicates a PG (pulse generator) slip error. This error signifies a discrepancy between the speed commanded by the drive and the actual speed of the motor. The PG, also known as an encoder, is a sensor that provides feedback on the motor's speed and position.
- Reset correct values for Pr.10-13 and Pr.10-14.
- Reset ASR parameters.
- Set correct accel./decel time.
- Reset encoder parameters (Pr.10-01).
