uC fault delta ms300 drive
Cause : Under current comes when the drive is detecting that the current flowing to the motor is lower than expected during operation.
The uC error code on a Delta MS300 drive indicates a general undercurrent fault due to improper setting of low-current protection.
  1. Troubleshoot the connection between the motor and the load.
  2. Reset Pr.06-71, Pr.06-72 and Pr.06-73 to proper settings.
  3. Check the load status.
  4. Check if the motor capacity matches the load.
