Delta Servo Drive
329
Dec 11, 2024 12:49 pm
Cause : Regeneration Error comes when a wrong regenerative resistor is selected or the external regenerative resistor is not connected.
AL005 alarm in delta ASDA-A2 servo drive indicates Regeneration Error. This means the regenerative braking energy is exceeding the capacity of the built-in or external regenerative resistor. This typically occurs when the motor is decelerating rapidly or when the load on the motor is suddenly released.
- Check the connections for the regenerative resistor.
- Check if parameter P1-53 of regenerative resister is set to zero.
- Check the setting values of parameters P1-52 and P1-53.
