Delta Servo Drive
332
Dec 11, 2024 12:47 pm
Cause : Overspeed comes when the difference between the command speed and the feedback speed exceeds the allowable range set by P2-34.
AL007 alarm in delta ASDA-A2 servo drive indicates Overspeed. This means the actual speed of the motor exceeds the maximum allowable speed set in the drive parameters.
- Use the scope to check if the signal of analog voltage is abnormal.
- Verify that the speed command sent to the drive is within the allowable range.
- Check the maximum speed limit and acceleration/deceleration rates.
- Check for any mechanical obstructions or binding that may be causing the motor to accelerate excessively.
- Use a tachometer or other monitoring tools to measure the actual speed of the motor.
