Delta Servo Drive
453
Dec 11, 2024 12:45 pm
Cause : Excessive Deviation of Position Command comes when the deviation of position command exceeds the allowable setting value.
AL009 alarm in delta ASDA-A2 servo drive indicates Excessive Deviation of Position Command. This means the maximum position deviation is set too low.
- Check the setting value of parameter P2-35 (The warning condition of excessive position deviation).
- Check if the setting value is appropriate.
- Check the torque limit value.
- Check the external load.
