Delta Servo Drive
343
Dec 12, 2024 4:43 am
Cause : IGBT Overheat comes when the load is over the rated range and the servo drive is in a persistent overload condition. The temperature of IGBT is too high.
AL016 alarm in delta ASDA-A2 servo drive indicates IGBT Overheat. This means the Insulated Gate Bipolar Transistor (IGBT) module within the drive has exceeded its maximum safe operating temperature.
- Check if it is overloading or the motor current is too high.
- Check the drive output wiring.
- Increase the motor capacity or reduce the load.
