AL024 alarm in delta servo drive
AL024 alarm in delta servo drive indicates Encoder initial magnetic field error. This means the initial magnetic field of the encoder is in error. Signal, U, V, W of the encoder magnetic field is in error.
  1. Check if the servo motor is properly grounded.
  2. Check if the encoder cable separates from the power supply or the high-current circuit to avoid the interference.
  3. Check if the shielding cables are used for the encoder.
