AL067 alarm in delta servo drive
AL067 alarm in delta servo drive indicates Encoder temperature warning. This means encoder temperature exceeds the warning level. But it is still within the protective range.
  1. Check the setting: Set the value of P0-02 to 120 to display the temperature.
  2. Improve heat dissipation or reduce the loading of operation.
  3. The temperature should be lower than 100°C (212°F).
