Delta Servo Drive
220
Dec 12, 2024 5:29 am
AL249 alarm in delta ASDA-A2 servo drive indicates the number of PR command exceeds the limit. This means the triggered PR path exceeds 63.
- Check if the PR command jumps to the path that exceeds the range and if the PR command format is correct.
- When the alarm occurs, please use DI:Alm Reset or write 0 into P0-01 to clear the alarm.
