Delta Servo Drive
162
Apr 28, 2025 12:01 pm
Cause: Position Error out of range comes when the actual motor position differs too much from the commanded position beyond a preset allowable limit.
delta al009 indicates a position Error out of range. This means the difference between the commanded position and the actual position of the motor has exceeded a certain threshold.
Follow these steps to correct delta al009:
- Inspect Load and Mechanics: Check for any binding, excessive friction, or unexpected loads on the motor.
- Examine Command Signals: Monitor the position commands from the controller to the drive.
- Review E-Gear Ratio: Confirm the electronic gear ratio is set correctly.
- Verify Gain Settings: Ensure the servo gains are appropriately tuned for your system.
